Points as breakpoints for line selection
871
08-10-2021 02:11 AM
Labels (3)
FynnScharpen
Hello there, I'm searching for a way to set points as breakpoints for select by location. So once the line selection hits them it wont go any further.
In my example (see attached file) No. 1 and No. 2 first connect to the dashed lines. Followed by the orange line in both cases. The problem: its splitted at the intersection with 1 into 2 pieces so I had the idea of using boundary touches. So in case I only wanna find out the lines from 3 to triangle it works but in case of using the same model for 1 to triangle its also selecting the lines above and right of the traingle which shouldnt be the case.
If you have any suggestions or tips please let me know.
Kind regards Fynn
