Parcel Fabric Pro Align Parcels Issue
1071
03-30-2020 10:27 AM
MichaelSnook
Hi All,
I'm trying to get the Align Parcels workflow down but it doesn't seem to be working.  I am wondering if I'm missing something and if anyone has any tips.  I've got 2 very simple parcels that I copy-lines-to'd from a CAD drawing...only the lower left corner is currently coincident with a corner so I added links to the other corners.  Then I click the 'Align' button but nothing happens.  Am I missing something?
Also, when trying to add links with tolerance I get a 'Links cannot be automatically generated. Please add links manually.' message.  Any ideas?
The fabric is in a file geodatabase, converted from an ArcMap fabric and running Pro 2.5.
Thanks
Mike
MichaelSnook
So, I just published the Pro fabric (copying the same FileGDB above in enterprise) into Portal and it seems that Align Parcels works as expected.  We're still in the test phase of migrating our 10.x fabric over full and was hoping to test out/troubleshoot in a file geodatabase but I'm glad to see that it works fine via enterprise.
New environment is Portal/AGS 10.8 and Pro 2.5
Thanks!
Mike
