Output data location changes to scratch.gdb in modelbuilder after unpaking ppkx
1905
01-18-2021 10:38 AM
vantoniou
I have created a ModelBuilder model in ArcGis Pro, where the location of all outputs is set to the Project's geodatabase. Also, the environmental settings of the Analysis and Model are set to the same geodatabase. I shared the Project as ppkx.
After the file is unpacked, the Model shows a lack of input's data path (except for the case that the data has been previously added to a map saved in the project and have been added to the model from contents with drag 'h drop) and also all output data stored directly to a scratch.gdb geodatabase, even the final output.
Any ideas?
DanPatterson
MVP Esteemed Contributor
 was it set to share outside an organization?
Share a project package—ArcGIS Pro | Documentation
... sort of retired...
vantoniou
Yes... I also tried this option..
Chris01
I'm having the same issue. inputs of the model are drag 'n drop and original output points to project .gdb. once unpacked outputs change to %scratch%
