Optimizing Area Solar Radiation Tool Performance
1563
05-20-2024 04:25 AM
AlexKazemi
Hello,
I am using the Area Solar Radiation tool in ArcGIS Pro. My DSM layer files are large, and reducing their resolution introduces significant errors, so I cannot lower the resolution. To speed up the simulation, I have split the raster DSM layer file into several smaller sections, but the simulation still takes a long time.
Is there any other solution to speed up the simulations? I have also tried increasing the processing parallel factor, but it did not work; I believe ArcGIS Pro does not support parallel processing for this tool. Any recommendations?
Thank you.
DanPatterson
MVP Esteemed Contributor
area solar radiation is a deprecated tool and will be removed in a future release,
did you try the recommended tool to see if things are different?
Raster Solar Radiation (Spatial Analyst)—ArcGIS Pro | Documentation
it supports gpu and the parallel processing factor
... sort of retired...
