Obtain Globalid From Another Table
1844
06-08-2021 03:01 PM
oakmn
I have a standalone table that has an id field named "media_table_id".  I also have a feature class that has an id field with those same values and it has a globalid field.  I would like to be able to populate my standalone table with the globalid's from the feature class, where the id's match and contains 'tbl_flare_ends" from the layername field in the standalone table.
Would I need to write an sql to do this?  Something like:  standalone.media_table_id = feature_class.id_field WHERE standalone.layername = 'tbl_flare_ends' ?  Or would I have to do some type of join to populate globalid values that match the criteria?
DanPatterson
MVP Esteemed Contributor
joins?
Join Field (Data Management)—ArcGIS Pro | Documentation
Add Join (Data Management)—ArcGIS Pro | Documentation
or similar?  That latter join is temporary
... sort of retired...
oakmn
Dan,
Even if the stand-alone table / related table has multiple entries with the same objectid?
DanPatterson
Kelly, just below the add join is "relate"  (many to one)
Add Relate (Data Management)—ArcGIS Pro | Documentation
oakmn
Thanks Dan.
When joining, it does not bring the globalid field with, so I am not able to calculate a new field with those values...
