Network Data Set Edit on SDE (Traditional Version)
2222
6
10-02-2023 11:16 AM
KumuduDesilva
I am trying to edit Network data feature class that I used to create the Network data set on ArcGISPro. But it is not allowing, and it says insufficient permission. Checked all the permissions and it all good. Anybody is having the same issue or? Am I missing something.?
thank you so much,
Ku De
George_Thompson
Esri Notable Contributor
Is this in an Enterprise Geodatabase or file geodatabase?
Can you provide a screenshot of the Feature Dataset that has the Network Dataset?
How are you connected to database: O/S or DB authentication?
--- George T.
KumuduDesilva
Enterprise and connected via O/S. I am sorry I cannot does not provide the screenshot since; it is internal.
thank you so much.
George_Thompson
did you load the data as your O/S user or a DB user?
If as the DB user, did you grant permissions to edit the data to your O/S user?
Is your O/S user part of an AD group used for login?
I also assume you are using SQL Server?
--- George T.
KumuduDesilva
1. DB
2. Yes
3. No
4. Yes
thank you
George_Thompson
After you versioned the feature dataset (FDS), did you add any new feature classes to it?
Can you give a screenshot of the versioning settings for the FDS?
Also, for the permissions screenshot, you can mark / blur out the names, just need to see the check boxes matched to a user line?
Based on the error message there is something misconfigured. It may be difficult without screenshots. You can contact technical support and they can do a screenshare to review.
--- George T.
KumuduDesilva
Is network dataset supporting only traditional versioning or both? Also, yes, I will contact the customer support. Thank you so much for your help.
