Network Analyst
1085
01-25-2023 11:05 AM
temprobertcottreau131313
I'm using network analyst in ArcPro to find the best route for a group of points.
I get a result with a route line but I'd like to have my points be labelled according to sequence with the sequence number inside the point.  Is there an automated way to do this?  Is there a way for Network Analyst do this for me?
Thanks to all.
Taren_Esri
Hi @temprobertcottreau131313
Your "Stops" feature class within the routing layer group should automatically label itself based on the sequence field (the order of how the stops should be visited). You may just need to toggle it on in the Contents, or re-add the layer to the project.
Best,
Taren
That's what I expected but it didn't happen.
I actually figured out another way in Labelling to select Label Placement As Centered Point and to set the Field box to Sequence.  In ArcMap there was an option to scale the label to the size of the point but I couldn't find this is Pro so did it manually.
