Network Analyst Connectivity Issue
822
04-06-2025 02:27 PM
CoenPartners2020
Hi there. I'm looking for some ideas on why when running the location-allocation network analyst or closest route network analyst do not utilize most of my demand/incident points. I can't tell 1) if it's a demand point issue or if 2) it's a network connectivity issue.
I utilized this youtube video as a step by step guide to create the ND and format the data. https://www.youtube.com/watch?v=5EKMOmMNl34&t=607s
What I have done to verify the network:
  1. Created and validated topology for all intersections & rebuilt the network.
  2. All dangles were fixed, all intersections are identified with network junctions (see below)
  3. No build errors were identified or "dirty areas" identified
ND Routes & JunctionsND Routes & Junctions
Just walking through the facility & demand input. I originally had a walk travel mode and had a time cost, same error was occurring so I simplified the network dataset to basically defaults and used meters to calc time.
ND SettingsND Settings
The farthest distance a centroid point I was utilizing for the demand points would be from the network was 35m. I've set to 50 to ensure it can snap to something in the network
Import Facility Location SettingsImport Facility Location Settings
In the attribute table, the facility points all have status as ok, all snapX snapY are filled out. Everything looks as if it's reading. No errors saying can not locate.
Facility AttributesFacility Attributes
Same process for the demand points. No weights, nothing that might have null fields. Same situation as facilities, no errors, status is ok, etc
Demand Point attributesDemand Point attributes
This is the error that appears when I solve. As you can see, most of the demand points are completely ignored.
Error MessageError Message
I ran a serve area test to see if there were any noticeable network blank spots, but didn't see any
Any help or ideas would be really appreciated. Thanks!
