Multipoint feature class in Topology
857
12-02-2025 07:21 AM
vijaybadugu
When i try to add feature class to participate in topology. I was getting an error "The geometry type (MultiPoint) of the feature class is invalid for participation in a topology". is there a way to support or work around for this?
MarceloMarques
Direct Answer
Yes, ArcGIS Pro geodatabase topology does NOT support multipoint feature classes. When you try to add a multipoint feature class to a topology, you will get an error:
“The geometry type (MultiPoint) of the feature class is invalid for participation in a topology.”
Why is this the case?
Geodatabase topology in ArcGIS Pro is designed to enforce spatial integrity rules among point, line, and polygon feature classes.
Multipoint geometry is treated differently because topology rules rely on relationships like shared edges or coincident points, which do not apply well to multipoint collections.
Topology in ArcGIS—ArcGIS Pro | Documentation
Supported Geometry Types
Point
Polyline
Polygon
These can participate in topology and have associated rules (e.g., Must Not Overlap, Must Not Have Gaps, Must Be Covered By).
Geodatabase topology rules and fixes for point features—ArcGIS Pro | Documentation
Workarounds
If you need topology-like validation for multipoint data:
Convert multipoint to single-point features using tools like Multipart To Singlepart or Feature To Point before adding them to a topology.
Alternatively, use attribute rules or custom scripts for integrity checks on multipoint datasets.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
Direct Answer
Point
Polyline
Polygon
Workarounds
