Move Snapped Verticies
1057
03-21-2024 01:09 PM
SimonDolega
Is it possible to move snapped verticies together? This feature is available on QGIS, I believe it is the magnet tool.Screenshot 2024-03-21 160437.pngSnapped PolygonScreenshot 2024-03-21 160450.pngVertices unsnap when moving
Robert_LeClair
Esri Esteemed Contributor
Yes.  With a Map Topology enabled in ArcGIS Pro, you can move coincident nodes quite easily.
RhettZufelt
MVP Notable Contributor
Not sure what you mean by moving 'snapped' vertices together.
You can hold the shift down and select (or drag to select) multiple vertices and they will all move together.
R_
