Modelbuilder ERROR 000272: Cannot open the input dataset, run again and works
3376
02-05-2024 06:07 AM
Iron_Mark
Hi, I have a model in modelbuilder that works, but when I run it for the first time it gives me the following error:
 I then delete the created fields and re-run the model again and it works.
Do you know why?
I am using Arcgis version 3.1.0.
Thank you
RhettZufelt
MVP Notable Contributor
Many times, this is because you are piping the output from one tool into the input of another tool.
If it is creating/modifying a temp dataset, then the first tool would need to be run successfully before the"dataset" exists for input into the second tool.
R_
Iron_Mark
Hi Rhett,
Thanks for your answer. I tried to modify the model in various part of it but I had no luck in solving the issue.
Do you have any suggestion?
PalakPandey
Were you able to fix this issue? I am getting the same and it appears i have to configure the tool each time i run.
Iron_Mark
I have temporarely switched to the Arcgis pro notebook connecting with gis = GIS('home') . This enables you to connect to the portal if you are logged in.
It is not what I wanted (I wanted to use python outside Arcgis for this task) but couldn't figure out the issue
