Model Builder: Feature layer not showimg up in the table of contents after running feature class to feature class tool
3008
02-23-2021 09:13 AM
LindaSlattery
I am creating a model in ArcPro and am using the Feature Class to Feature Class tool. I want the new feature class to show up in the table of contents, like it does when I run it manually. But it doesn't. It creates the new feature class in the GDB. If I can't do this, can someone help with how I add data using Model Builder and I can add it that way. I am using ArcPro version 2.5
Thanks!
Tags (1)
KoryKramer
Esri Esteemed Contributor
I know that improvements were made with Add to Display in ArcGIS Pro 2.7: https://pro.arcgis.com/en/pro-app/latest/get-started/whats-new-in-arcgis-pro.htm (ctrl+F 'add to display')
I don't have a machine with 2.5 on it to check, but have you looked through https://pro.arcgis.com/en/pro-app/2.6/help/analysis/geoprocessing/modelbuilder/run-a-model.htm ?
KoryKramer
LindaSlattery
Thanks, Kory. That option is available in 2.5 and it worked! Much appreciated!
