Missing field in csv
12879
13
10-13-2015 04:23 PM
TinaGrant
I have a table saved to a .csv in LibreOffice. When I add the table to ArcMap, the last field is missing. The whole column just...gone. Suggestions?
TinaGrant
Nothing fancy here, just integers and text.
RebeccaStrauch__GISP
You can't copy it to an xls, but do you have any other options?  .dbf or a true .csv ?
TinaGrant
And there it is...I opened and saved the file as a .csv with Notepad++. Added it to the map, and the missing column appeared! Thanks for the help
NeilCurri1
I was having this maddening problem as well and did the same workaround. Exported CSV from MS Access. Excel wouldn't see this column. ArcMap wouldn't see this column. Finally, I opened up the exported CSV in Notepad and saved it as a CSV again from Notepad with another file name and ArcMap saw my missing column.
