Merge Layer Tool Not Working
1462
7
09-29-2025 12:33 PM
ColleenHeemeyer
Hello, I'm trying to use the "Merge Layers" function to merge two point layers (both are .xlsx tables that I've geocoded--using the same data fields for both. The tool doesn't work, and generates the following error:
Merge Layers
Tool Path
Input Layer     2025_Grants_Geocoded
Merge Layer     SSP_Grants_1986_2024
Output Name     Grants_1986_2025
Merging Attributes
Output
Data Store     SPATIOTEMPORAL_DATA_STORE
Messages
Start Time: Monday, September 29, 2025 15:04:30
Unable to get geoanalytics URL.
Failed script Merge Layers...
Failed to execute (MergeLayers).
Failed at Monday, September 29, 2025 15:04:31 (Elapsed Time: 0.69 seconds)
When I google this error, I see that it could be caused by my "geoanalytic server" being misconfigured. How do I check on that?
DanPatterson
MVP Esteemed Contributor
are you using enterprise 11.3 or earlier? it is a deprecated tool
Merge Layers (GeoAnalytics)—ArcGIS Pro | Documentation
... sort of retired...
ColleenHeemeyer
Thanks.  I saw that, but I didn't know what it mean.
So...there's now no way to merge two point feature sets?  At least, there's no way that I can find.
DanPatterson
ColleenHeemeyer
And I get the error message with the Merge Layers tool.
Sigh...this worked so well last year.  WHY DOES ESRI MAKE THIS SO COMPLICATED????
DanPatterson
If the source layers are not featureclasses in a locally stored file geodatabase, convert them to that.  You mention xlsx files, as event themes, I assume.
Laura
by MVP Regular Contributor
Is this the tool?
What version enterprise?
ColleenHeemeyer
I just wanted to say thank you to everyone who tried to help.
When I looked at the layer into which I wanted to merge the new data, I found there was a lot wrong with it.  An entire year was missing, an entire county's worth of projects were missing.  So...I redid the layer, adding the missing year, and correcting/rematching addresses that didn't geocode.  This solves my problem for this year.  Who knows what will happen next year!
