Measure and Create Line
4087
12
11-05-2018 11:35 AM
MichaelFettkether
I'm having some trouble with the Create Line "right click distance" feature.  If I measure a distance and then try to create a line of specified distance, the two do not match.  It appears the distance entry is not accurate when I sketch something.  ArcGIS Pro 2.2.3
MichaelFettkether
Came into work this morning and opened my file, and the issue is back after yesterdays fix of Save > Close > Re-open.  I tried this procedure again, but the issue did not resolve this time.
Scott_Harris
That's very odd that the problem returned. So you opened the same project and the same map, and the problem persists? Had you made any other changes to the map or the data in the map?
On my end, I can't reproduce the problem after closing out of Pro and restarting the computer, and then reopening the same project to the same map.
That's the thing with bugs, however, sometimes they cause unexpected behavior like this. Now that it is reported to the development teams, they can look into it further, and hopefully have a fix.
The good news is: I can't reproduce the bug in the latest (unreleased) build of ArcGIS Pro.
RonaldoKnychala
Hello Michael, I'm having the exact same problem, but I was trying to create a Circle with a Radius, have tried all as you have and it does not work, I'll let you know if I figure it out, please let me know if you do too. Tks
