map series
2054
11-16-2020 07:39 AM
MarcelSt-Germain
Hi,  maybe I done something wrong but, with map series I have questions.
I make a basic map and layout.  When I try to change my query, in my page series polygons, it's take forever to accept the change.  Have to do it many time before the change is ok.
The problem after that is that the map series doesn't change.  I have to close the aprx an open it again to see the change applied.  Maybe I doesn't wait enough?
RickeyFight
@MarcelSt-Germain
Do you have caching turned off for that layer?
MarcelSt-Germain
Frankly, doesn't know where to look
RickeyFight
AubriOtis
If you aren't seeing the change right away, you may need to refresh the map series.
For more information see this help topic: https://pro.arcgis.com/en/pro-app/help/layouts/refresh-map-series.htm
Cheers,
Aubri
