map series with postgresql database
903
03-14-2023 10:00 AM
tethys_srl
Hello all!
I'm trying to create map series with ArcGIS Pro basic 3.1 and postgresql database 13.5 (postgis 3.1.4).
I made all the steps following the online procedure, and no errors/messages were returned but in the "contents" tab no map series appeared.
I exported the same data in a feature class in a local esri geodatabase, I made all the same steps and it works perfectly (but I need to use postgresql).
Online I didn't find any clues that this issue could be linked to the licence or to a particular extension needed.
Is it and expected behaviour or is this a bug? Any suggestions?
Thank you
Cesare
George_Thompson
Esri Notable Contributor
Only initial item I saw was that your version of PostgreSQL & PostGIS is below the supported version: https://enterprise.arcgis.com/en/system-requirements/latest/windows/database-requirements-postgresql...
That could cause an issue.
Is the DB an Enterprise Geodatabase or just a database?
--- George T.
tethys_srl
Hi George,
I updated postgresql and postgis to the supported version but I have the same issue.
I have only a database, not an Enterprise Database. I tried to uso also different feature classed but map series don't work with postgresql.
Could it be a bug? Any hints?
thank you
Cesare
