Map Scale vs Printed Out
1084
01-09-2025 01:01 PM
asloan3
Is there a way for you to know exactly how your map will look in real life? For example, if I create a map that is 11x17 and has labels, I would like to make the zoom percentage reflect how the labels would look printed out on an 11x17 sheet of paper. Thanks!
Laura
by MVP Regular Contributor
If you choose your layout size in Pro to be 11x17 then it should match pretty well to 11x17 in real life. You van also preview it the print preview. I usually set my layout size and then play with the labels from there.
