Map Projections - ArcGIS Pro
2791
06-08-2017 12:02 PM
ExecutiveStaff
Hello all,
I am currently working on a map project in ArcGIS Pro that displays a preserve poly boundary paired with some poly boundaries displaying areas of interest. In our database we have a variety of different poly boundaries that have either been created or sent from external sources for our preserve, but when added to the map all are situated in slightly different locations (different map projections I'm assuming). I like to work out of NAD 1983 CA State Plane Projection when working on maps regarding a preserve, so that is the coordinate system that my map is set as. Within the toolbox in Pro I have re-projected my layers using the "Project - Data Management Tool" to match the system of my map and nothing appears to happen. Additionally, I utilized the "Define Projection - Data Management Tool" to attempt to reset the coordinate system which results in my layers being sent to a "null island" only this time in the middle of the Pacific Ocean. Are there any further steps I can do to ensure and/or double check that my layers are pairing up correctly with my map? Hopefully this is a easy fix and everyone is able to understand my question. Let me know if you need any additional info to describe the problem.
KoryKramer
Esri Community Moderator
Jakob Larson‌ You mention that your map is in NAD 1983 CA State Plane (zone ?)  When you check the data that is being added to the map, what is it's coordinate system (before you used Define Projection)?
At first glance, this does look like a datum shift, though its interesting that there are three shifts, and I'm not sure if that could be because you used Define Projection before the screenshot?
Anyway,  if the data had a coordinate system from a different datum than the map (say NAD 1927), and you don't apply a transformation, you'll see this shift.  You'll probably want to go into your project Options > Map and Scene and enable the 'Warn if transformation between geographic coordinate system is required to align data sources correctly' option.
Transformation Warning
If the data that you're receiving has a coordinate system defined, we should assume it is correct until proven otherwise.  That means that you should not use Define Projection—Data Management toolbox | ArcGIS Desktop  "The only use for this tool is for datsets that have an unknown or incorrect coordinate system defined."
It is good practice to project all data into the same coordinate system so that you aren't projecting on the fly especially when editing or doing analysis.  So using the Project—Data Management toolbox | ArcGIS Desktop tool is good.  From first glance here, it looks like you'll need to apply a transformation in the tool.  Did you do that?
If all data is projected into NAD 1983 California State Plane (same zone), and that is what the map is in, there will no longer be a need to apply a transformation to the map, and even if you have that option enabled, you shouldn't get any warning.
I hope this info is helpful.  If you're still seeing issue lining up the data, send some more info about what the original coordinate systems are (again, before you've used Define Projection on them).
