Map Frame choices have disappeared in ArcPro
897
09-15-2025 02:30 PM
TashaLowrey
Hello ESRI Community,
I have to go back and redo old maps to print with updated data, but I used to have map frame options other than a thicker line or a different color.  Like three lines to enhance my maps, etc.  What happened to this option?  Do I need the Advanced licenses in ArcPro?  I have looked online and tried all the options, but they are not relevant and do not provide the correct solution.
Thanks for any help.
Tasha Lowrey - GIS Tech
Fernley, NV
DanPatterson
MVP Esteemed Contributor
Add and modify map frames—ArcGIS Pro | Documentation
map frame properties?  under Modify the border, background, or shadow
... sort of retired...
TashaLowrey
I did do that, but it won't let me change it from a solid line.  Before I had the choice of difference border selections.  I just tried it again.  I can change still change the Background, Shadow but the Border will only let me have a solid line, I can change color or size but not style.  Before in ArcMap I had border frame choices.
Thank you for replying to my help note.
AubriOtis
Hi! To change the border line style first click the line preview for the border. This launches the full style editing experience.
Then you can play with thickness, dashes, stroke type, and more.
Cheers,
Aubri
