Making Drop Down Menu between 5-100 in .1 increments in a Domain for Attribute Table in ArcPro
1604
04-13-2022 12:21 PM
HMorrell
Hello,
I am making an attribute table for a Feature where we are recording different tree measurements. I am trying to create a Domain which will serve as a drop down menu for measurements in inches. I would like to have a list of numbers to choose from between 5.0 inches to 100.0 inches in 0.1 increments. Is is possible to automate this somehow because I do not want to type out every number between 5.0 and 100.00 in 0.1 increments.
Thank you so much!
KimberlyGarbade
I would create it in Excel.  Export to .csv and then use:
Table To Domain (Data Management)—ArcGIS Pro | Documentation
HMorrell
Thank you so much! I will try this right now.
Have a great day!
KimberlyGarbade
Did it work with so many values?... It worked when I tested it on 20 or so values, but I've never created a domain that long before.... an image of the Excel I saved as .csv and imported is below.
