Looking for a way to configure the Identify button in ArcGIS Pro to work like the one in ArcMap
1592
11-03-2023 12:58 PM
JoseSanchez
Godo afternoon,
Is there any post , article or vide that explains ow to configure the identify button in ArcGIS Pro line like one in ArcMap.
Several users are missing these ArcMap features.
ThomasHoman
Can you specify what specific ArcMap Identify functionality(ies) you are trying to replicate in the Pro Explore tool?
I think there might be some short answers to start with:
Clicking on a single feature - Pro's Explore returns the configured Pop-Up for the particular layer. Right click on the feature class and select Configure Pop-Ups  https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/configure-pop-ups.htm
Data from multiple features - Use Pro's select tool then get the results from the Attributes pane instead.
Regards,
Tom
SanchezNuñez
Hi @ThomasHoman
This is what the users are looking for from ArcMap.  When using the Identify button they can select in the "Identify From" a specific layer, let's say the properties layer, and then when clicking on a property it shows all the attributes.
ThomasHoman
Hi @SanchezNuñez
Use the dropdown menu below the Explore button to change what is returned. I tend to use the 'Selected in Contents' option to filter what gets returned. This might help a bit - https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/pop-ups.htm
Regards,
Tom
