Legend Issues ArcPro 2.6.0
2399
10-01-2020 09:20 AM
MaryWagner
Recently we upgraded ArcPro to 2.6.0 and since then I have had issues with configuring the legend :
  • Layers showing up in an EXPORTED map even when turned OFF in the TOC Legend area and not showing up in the layout (the Aerial info specifically.)
  • Layers not reacting properly to the "show features in extent" option.  When activated, the legend frame shows nothing for that layer.
Is anyone else experiencing these issues?  My work around has been converting to graphics, but that is not ideal.
Thanks
Robert_LeClair
Esri Esteemed Contributor
Upgrade question for you - did you do a clean uninstall of the previous AGP release and then a clean install of AGP 2.6?  Or did you do an upgrade?
MaryWagner
The previous version was not uninstalled beforehand.  Our IT dept handles software upgrades/installs.
TomBole
Hi Mary,
 First, is your Aerial layer coming from a map service?  If so you may be running into BUG-000131306 (see
Unwanted Legend Item Appears After Export ).
I'm not aware of any known issue specific to this. There could a number of things happening and without more information about your situation there's little that can be done. Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Hope this helps,
Tom
MaryWagner
The "only show features in extent" seems to just be happening with one layer in my project.  I found a work around for now, but I will put a ticket in with ESRI Support.  Thanks for your response.
Mary
