Layer to KML
1798
07-19-2019 09:41 AM
Bristlecone-Geo
3 times in a row, layer to kml crashed. Simple polygon (1), Pro 2.4 just wouldn't do it. But ArcMap 10.5.1 did. I've been getting a lot of little annoying errors in Pro. Do I need to implement the age-old ESRI solution to rename my registry to "old" and start again? Honestly I was hoping with the 64 bit version that would be a thing of the past...apparently not. pro bugs @Arcgis Pro
DrewFlater
Hi Pete,
I have two questions:
1. can you upload a layer package with this data
2. can you upload the crash report (.dmp) from your %localappdata%\esri\errorReports folder with the timestamp that matches when the application crashed running Layer To KML? There is no personally identifiable information in this report, so there are no privacy concerns. If you feel better, you could also email it to me at [email protected]
Thanks for your help troubleshooting the issue.
Bristlecone-Geo
Hey Drew,…
Attached are the *.dmp files. I’ll put the layer package together and email that separately. As it happened 3 times in a row, I included all 3!
Cheers,
Pete Magee
KoryKramer
Esri Esteemed Contributor
Pete. Please always include an email address when submitting an error report ArcGIS Desktop Error Reporter Learns Its Manners
It is very helpful!
Thank you
Bristlecone-Geo
I will, thank you.
