Layer to KML
1296
12-14-2020 10:45 PM
PersefoniKapotas
I am trying to convert a graphics layer to a kmz.  When I use layer to KML tool, it does not fail, but it does not produce a kmz file either.  I successfully created a kmz within the same project from a different graphics layer just a few days ago.  Now, nothing.
DanPatterson
MVP Esteemed Contributor
Hard to say why would or wouldn't given the rules that will determine what will work
KML conversion—ArcGIS Pro | Documentation
can you pinpoint what the difference between the two layers would be?
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
Is a Graphics Layer or is it a Feature Class from a geodatabase or shapefile in the Contents Pane?
