Layer to KML output Scale Dependency
1444
09-25-2019 08:51 AM
NickKenczka2
Hey all,
So I'm attempting to enforce some scale dependency when exporting a layer to KML to view in Google Earth.  My eventual hope is to enforce some label scale dependency but that probably isn't possible.  The more likely solution is to just make the layer scale dependent when exporting.  I've  been messing with different values in the tool with regards to the output scale options and I'm getting no positive results.  Regardless of if I put 5 or 10,000 in that option I still see every feature when importing the kmz into Google Earth.  Any ideas?  Thanks.
ChrisWiebke
I am seeing the same issue
