Layer to KML is not naming properly, possible bug
9924
19
03-19-2024 02:20 PM
ScottFinck
I am using ArcGISPro 3.2.2. The Layer to KML tool is not handling the names of point data the way it should. This used to work a few months ago. I don't know if we were using a different version then. I am using clamp features to ground and do not return single composite image. I set up the label color, size, expression and turned the labels on. They display properly in ArcGISPro. When I export the layer to KML, every feature name when viewed in Google Earth is the same because it is using a different field than the site_name field I specified to use. I have found a workaround by going to the layer properties>display>drop down and select the field I want to use for labeling. However, if I set up an expression in this area, it names everything based on the object ID for some reason. I need to be able to use an expression to properly name my features. This issue is not only happening to me but with everyone else in my group. I wrote a python tool to see if maybe the Layer to KML tool is broken but it does the same thing. That leads me to believe that there is a bug in the software. I would greatly appreciate if anyone had some insight to this issue. Thanks!
ScottFinck
I have found a partial workaround. This may work for Brodie as well but since he is using a script, I am not sure that it will. If you right click on a layer in your contents pane and go to properties and then display, there is a drop-down menu that allows you to select a display field. Use the field that works best for your output naming and it will use that for each KML label. Be aware though, that the expression function is broken in this location as well. The only option for getting a usable label is to select a single field to label from.
xcubbyxbearx
I had the same issue today as well as my colleague. I have a feeling this problem is a bit more prominent now in version 3.3.0, as I am able to recreate it often with multiple layers.
I set the display field in ArcGIS Pro, but when using layer to KML and opening in Google Earth, all of the attributes are named "no name".
JC-220
Same issue here. I'm back in 3.2.1 Setting the Display field will give me one label but I need 2+ for each point.
ScottFinck
Yep, I need 2+ as well for each point but for now I have to settle with one. It's almost unusable.
BeckyMackel2
Hey @myesri , @esriesri , @RDESRIwhat is the ETA for fixing this bug?
PakinamSwielim_hatch
Hello
As a work around, I have export the KMZ file in Global Mapper to a shapefile and then open the layer in ArcGIS and each point came with the correct name
JesseWickizer
This issue has been fixed in ArcGIS Pro 3.3 and patched at version 3.2.4.
BeckyMackel2
@JesseWickizer thank you, that is great news!  I just checked for updates (am running Pro 3.3.2) - and see there are no updates available.  When will the patch be available?
JesseWickizer
This change is reflected in the 3.3.2 version of pro that you're using which is currently the latest version.
AliciaLittle
Hi Jesse I'm running 3.3.2 (just updated to it today) and still having this problem with Layer to KML making all my polygons named [no name] in the resulting KMZ file. Can you assist? I have tried the following:
- making a plain text NAME field as sometimes the Layer to KML tool will just automatically use that as the names for the polygons (didn't work this time)
- setting the Display Name to the NAME field or the MAIL_NAME field which is the original field I wanted used for the names of the polygons (didn't work)
- updating from 3.0.3 to 3.3.2 (no change)
Can you please advise further things to try? I have nearly 5000 polygons with unique names that I need to be listed as the names of the polygons within their folders in the KMZ when opened in Google Earth Pro.
Thanks!
EDIT: Finally got it to work by converting the fc to a shapefile and then using layer to kmz!
