Layer missing from legend after creating custom symbology
12966
20
09-13-2017 09:01 AM
TaylorBruecher1
I created a legend, then changed the symbology of one of my layers.  I used the Expression Builder in the Symbology pane to create custom symbology and the layer disappeared from my legend.  It is listed in the legend tree in the Contents pane, but isn't showing up in the legend. I deleted the legend and recreated it, and the layer still isn't showing in the legend. Any thoughts?
CraigWilliams
We're looking to finish up dev by the end of the year.
deleted-user-uq8YvhZW77jR
Hi Craig, has this been done now? I'm experiencing the same problem.
thanks
Frida
TomBole
Hi Frida,
Which version of ArcGIS Pro are you using?  I can reproduce this issue with 2.0, but I cannot with version 2.1 or later.
Tom
JohannaPrüssmann
Still no solution? I'm having the same problem
TomBole
Hi Johanna,
Tom
JustinConnerWR
I had a layer disappear from the legend.  I copied and pasted it (then had to adjust the formatting of the patch to match other layers), but at least I was able to fix the legend issue.  (2.2.1).  I don't have time to try to reproduce the bug; hopefully someone at ESRI can track it down.  (I had restricted the legend to showing only symbols for features w/in the map extent, and added the layer after that, so perhaps that was the problem?)
TomBole
Hi Alison,
The only scenarios where layers should disappear from the legend are:
  • Removing the layer from the map
  • Checking the Legend item "off" in the Contents Pane.
  • The layer is not visible because it is turned off in the map, or it is not visible because a visibility range has been set on the layer and the current scale on the map frame (that the legend points to) is out of this range AND the legend property "Layer visibility" is checked on (Format Legend > Options tab - Synchronize with map group).
  • The legend item (layer) has "Only show features visible in the map extent" (Format Legend Item - Feature Display Options group) is checked and the map extent is such that no features of the layer are visible. This is set for individual legend items, which requires a layer already present in the map, so I'm not sure how you are able to set this and THEN add the layer. Perhaps I'm missing something?
I'm not aware of any outstanding issue where legend items unexpectedly disappear from the legend. Unfortunately, if you are experiencing a bug we would need more information to investigate further.
You mentioned that you are doing some copying and pasting. If you are copying and pasting layer elements (such as map frames and legends) make sure that the pasted element is referring to the correct map ( in the case of a pasted map frame) or map frame (in the case of a pasted legend). You can find this info in the Options tab of the properties pane (Format Map Frame & Format Legend).
Hope this helps.
Tom
JustinConnerWR
The issue is that if syncing w/ new layers is OFF for the legend, and a layer is added, I have not found a way to add that layer into the legend (without removing it and adding it back in while "Synchronize with map --> New layer" is on).  Below, I created the legend when only Cities was in the map.  I then set the US Cities layer to only show features visible in the map extent, then turned off the layer sync in the legend properties.  I added the Counties layer.  When I re-check the New layer option for syncing, the legend remains limited to US Cities.  If I spent a lot of time formatting the legend while "New layer" was unchecked in the Sync options, and added a few new layers, the workaround of deleting/re-adding the layers would make more sense than creating a new legend.
TomBole
Hi Alison,
If the "New layer" option is checked off you can add new layers to the legend by either dragging and dropping the new layer from the map portion of the Contents Pane into the legend portion of the Contents Pane or onto the legend element on the layout view itself.
Tom
JustinConnerWR
Thank you. Can other drag-and-drop functionality (such as dragging a map into a layout) be added to make this more intuitive?
