LAS Dataset Build Pyramids not saving
581
12-02-2025 10:22 AM
Yeaton
I have a dense LiDAR point cloud that I have created multiple LAS datasets to build pyramids on.  I have the temp/scratch folder redirected to a location with enough disc space.  The pyramids build fine and I can work with the resulting LAS data, but when I save and close ArcPro the pyramids seem to go away as when I reopen the project pyramids have to be rebuilt.  Am i missing a step to save the pyramids within the LAS Data set?
Thanks for any help.
Best,
Aaron Y.
DanPatterson
pyramids are directed to a folder where the las dataset is located
LAS dataset pyramids—ArcGIS Pro | Documentation
is the las data *.lasd?
Build LAS Dataset Pyramid (Data Management)—ArcGIS Pro | Documentation
also see Create LAS Dataset (Data Management)—ArcGIS Pro | Documentation
assuming this is the tool you are using to build the pyramids
... sort of retired...
