Labeling in ArcGIS Pro
1138
07-15-2020 07:43 PM
ThaoNDP
Hi everyone! Can I set the position of the label for the buffer polygons as shown below? They should be oriented in the same direction, not in free positions. Thanks for any help!
by Anonymous User
Not applicable
Hi Thao Nguyen‌,
Yeah you should be able to find all you label properties for ay layer in ArcGIS Pro in the following window.
Right click on the layer, select label properties and then navigate to the position tab. This will give you all your labelling position options.
Cheers,
Cam
by Anonymous User
Not applicable
Hi Thao Nguyen‌,
Cheers,
Cam
