.kml file to layer
3144
6
03-02-2022 12:43 PM
SLouq
by MVP Alum
I was given a .kml file and asked if I could provide the coordinates for each point in it.
How can I do this in ArcGIS Pro?
When I try the KML to Layer tool it tells me empty dataset
JayantaPoddar
Check if you have access to the KMZ (zipped KML) file.
In case you don't, you could convert the KML to KMZ using KML to KMZ Converter Online - MyGeodata Cloud
Use the resulting KMZ file in KML to Layer tool.
It should give you the desired output.
You could then use Calculate Geometry Attributes (Data Management)—ArcGIS Pro | Documentation to calculate the X (Lon) and Y (Lat) values.
Think Location
JayantaPoddar
Would it be possible to share a sample KML file (causing the issue) for us to test?
Think Location
SLouq
by MVP Alum
it's not letting me attach the .kml file. Says file type not supported
JayantaPoddar
zip and share
Think Location
SLouq
by MVP Alum
Thanks! I didn't think of that. Lol
JayantaPoddar
Think Location
SLouq
by MVP Alum
Thanks!
