Issue with Exporting Report in ArcPro - Disconnection of Third Feature Class ARCPRO 3.2
827
12-12-2024 12:15 PM
Labels (2)
AnasAlkhrissat
I am experiencing an issue with ArcPro while creating a report based on a feature class related to a second feature class, which in turn is related to a third feature class. When I attempt to export the report, clicking "Export" disconnects the third feature class, causing it to lose its connections.
I have re-established the connections, and everything appears fine, but the issue recurs each time I try to export. All data is stored in SDE. I also tried exporting the data to a file geodatabase with the same schema, ensuring that the relationships exist and are confirmed, but the same issue persists.
Could you please advise on the reason for this problem and how to resolve it? The issue specifically occurs when I click "Export," causing the disconnection in the relationships. Please note that the relationships work fine when tested in the data, map, and attributes (both in SDE and locally).
In summary, the related data source breaks in the third related feature class in the report in ArcPro.
Tags (1)
