ISSUE - Attribute Transfer Lag with Nearmap via AGOL Turned On.
1118
07-18-2025 08:32 AM
PeteJordan
  This is a recent problem I just encountered and not sure if it's related to the newest ArcGIS Pro Update 3.5.2 or if it's related to the Nearmap on AGOL issue that has been ongoing for the past few weeks (https://www.nearmap.com/status) or both?
  The issue is that using the Attribute Transfer lags severely when I have Nearmap via AGOL (the lastest working version that has come back online finally), is turned on.
  The tool works fine if I disable Nearmap from AGOL.  It also works fine with other imagery (WTMS Service) and another WMS service we have access to.  So I know it has something to do with the latest imagry that Nearmap and ESRI have temporarily got working.  Nearmap has said there are issues still, but wanted to double check this wasn't also a possiblity that the 3.5.2 update is aslo maybe adding to the problem as well?
  Not sure if this should be a bug report or not, because I'm not sure if it's only Nearmap via AGOL that is the issue, or if it's also partly due to the 3.5.2 update as well?
Thanks
Robert_LeClair
Esri Esteemed Contributor
There is a BUG-000177497 - "Authentication issues occur when attempting to access Nearmap US Vertical Imagery services following the ArcGIS Online June 2025 update"  Esri is working with Nearmap to resolve the issue.  May be related to what you're seeing...
Robert_LeClair
According to the internals, BUG-000177497 is fixed at the Q3 2025 ArcGIS Online release.
PeteJordan
As of 3.6.2, the issue still persists and there is still the lag with having Nearmap turned on compared to having it turned off...
PeteJordan
  Yes I had a case filed and it was already brought to the lead technician working on the issue.  So far with the latest patch, it still wasn't working properly.  It was assumed it stemmed from the BUG-000177497, but it wasn't verified at all that it was part of that bug or something else like a previous update.
  Either way, I just continue to turn off Nearmap when I need to do an Attribute Transfer as 3.5.3 patch didn't fix it...
