Intersect (Analysis) does not like "memory" workspaces. Is this a bug?
2839
7
11-25-2022 12:05 AM
Labels (3)
Cristian_Galindo
I am using ArcGIS Pro 2.9, and trying to make some basic spatial operations.
Two sets of features were selected from a geodatabase, and using them, an intersection will be performed.
As it is not intended to persist this objects, the script use the "in_memory" workspace (it was done for the version 2.1 thinking in ArcDesktop).
Today, in an attempt to update the script with the new characteristics of the version 2.9, I found that the intersect tool does not like the memory workspaces.
Here is my evidence:
reading the documentation of the intersect tool, it does not mention a restriction for this kind of datasets.
Is this a bug? How do I report it?
HannesZiegler
@Cristian_Galindo are you able to contact Technical Support Services? They will be able determine whether this is a bug and can file an internal issue if it is.
JoshuaBixby
Have you checked whether the issue is with selecting?  If something isn't working correctly with Select, it may be there isn't anything selected for Intersect to operate on.
Cristian_Galindo
As I posted as evidence, both scenarios are the same, the only difference is the location of the expected result. but in order to provide more evidence, i ran the scripts against an smaller dataset, and print the results:
Cristian_Galindo
After some trial and error (not you pity documentation) I found that Intersect tool does not like "memory" (modern, state of the art) workspaces as INPUT, it does not care about the output:
Cristian_Galindo
Additional Note:
The tool MakeRouteEventLayer does not like either the "memory" workspaces as input.
The documentation: https://pro.arcgis.com/en/pro-app/2.9/tool-reference/linear-referencing/make-route-event-layer.htm
does not state this.
RandyMcGregor_BMcD
I'm experiencing this today, 4-11-2025. Getting an error message that it can't create the in memory output. The thing is this tool has worked before. There is something about the intersect tool that creates conflict with in memory outputs.
RandyMcGregor_BMcD
Turns out the input line feature had a VERY long name. I exported to a feature class with a shorter name and it worked - successfully created an in memory output. To clarify, this is the actual name of the file. Changing the layer name in the table of contents didn't help.
