installing ArcGIS Pro on a 2TB external drive
4017
04-02-2020 01:48 PM
SpiccioliCaroline_M_
I have a mac currently running ArcGIS Pro through a virtual desktop with my university. However, I would like to try downloading and installing it on  2TB external drive. How would I go about this? What are the steps?
DanPatterson_Retired
ArcGIS Pro 2.5 system requirements—ArcGIS Pro | Documentation
check the link on that page
Check your computer's ability to run ArcGIS Pro 2.5.
Before you waste any time because I suspect the computing demand for standalone won't be the same as for your virtual situation.
Then there are the prerequisites.
Run ArcGIS Pro on a Mac—ArcGIS Pro | Documentation
So I actually don't need to run the software on my mac I just want to know how to install the software (or download something I could later install on a PC) to my external drive. The external is called SP Silicon Power Armor by the way.
Ahhh, If you have a university account
ArcGIS Desktop licensing—ArcGIS Pro | Documentation
You can download the *.exe file... don't run it from your download site... save it to a usb/thumb drive, and you can install it on your pc at home.
Of course the pc would also need to run the specification test to make sure it is good.  As for an external drive...keep it to save data, my personal preference though
I have a PC at home but don't have access to it at school, all I have with me is the Macbook air. After I leave the university I likely wont be able to download the software anymore so I wanted to do it now with the external so I could install it on the pc when I have access to it again. To clarify: I could use the mac to download everything onto the 2TB that I need to later install ArcGIS pro onto the PC? I've never really used this external drive before and apparently it stores everything in zip files so is that still okay?
Thanks for the hep!
download the *.exe file to the external... just don't install it on it was my suggestion
The *.exe file contains a *.msi and a *.cab file.  copy the *.exe file to your local PC, then double-click on it it will ask yoiu where you want to extract the files... do that, then when the files are extracted to a folder, double-click on the *.msi file to begin the installation process.
I install in a separate folder
c:\arcgis_pro
is a pretty obvious place and not in c:\Program files\blah blah  or words in the c:\Users\don't_install me here\
