Importing editable layers.
5278
15
06-22-2017 03:18 PM
TravisRamos
Hi, I'm trying to import an editable layer into Arc Pro. I've tried .csv, .txt, and even converted it to a Geoprocessing file. I'm able to import it to the map, but then am never able to edit the layer and it always shows up as a non-editable layer in the context tab.
Any advice?
Thanks.
Tags (1)
TimOrmsby
Without knowing the particulars, this workflow might be reasonable:
  • Convert your XY layer to a feature class. Call it SurveyTopoAsIs or something like that. It's your real data from the csv.
  • Make additional copies of the feature class as needed with the Copy Features tool. Name these SurveyTopoWhatIfA, SurveyTopoWhatIfB, etc.
  • Edit these copies as you want to model alternative scenarios.
TravisRamos
Thank you Tim. What I ended up needing to do was convert it to a feature class, as you stated above. That made the layer editable. I am now able to edit the layer and data as I needed.
Appreciate the advice and help very much.
TimOrmsby
Great, you're welcome. I think life would be simpler if the software just created a feature class directly from the text file.
DanPatterson_Retired
If you need to be able to edit the contents of the file without converting it to either a featureclass (and hence its table) or a table, then you might have to do your processing outside using python and numpy and/or Pandas.  If you could elaborate on what it is you need to do/edit, it might be easier to provide a concrete example.  There should be no obstacle to working with a non-event layer table in any workflow, since you can simply delete it when you are done, presumabley because you would export it back to csv when you are finished.
TravisRamos
Thanks for the response Dan. I'll be needing to take surveyed topography data and edit out some features in order to model a "what-if" scenario on a river.
Appreciate the help.
TravisRamos
Thank you Dan!
