Import MySQL Data into ArcGIS Pro
1139
02-02-2023 05:42 AM
MichaelVolz
Esteemed Contributor
Hello Community:
I would like to import MySQL data into ArcGIS Pro, but it is currently failing using a 64-bit MySQL Connector with an ODBC Connection.
I have added a new OLE DB Connection using the MySQL ODBC 64-bit connection I created on the machine.
I open up the database connection in Pro's Catalog Pane and I can see all the tables in the view.
I then right click on the table in the Catalog Pane and choose Add to Current Map.  When I right click on the table in the map's Content pane, I get the error "An invalid field name was used in a query string (0x80040204)."
Does anyone know why this would be occurring and how I can get past this error?
Tags (4)
