Import mesh file using import 3D objects tool (.obj and f.bx)
872
10-20-2025 12:45 PM
Letíciad_Agosto_Miguel_Fonseca
Hello everyone,
I'm trying to import a mesh file (.fbx) processed using Pix4D into ArcGIS Pro using the Import 3D Objects tool. My mesh is imported without the correct Z-coordinate and is located at the origin (0,0 coordinates).
Even though I haven't defined the vertical coordinate system, the point cloud is imported correctly.   I've already tried using the Project tool, but I believe I'm missing a critical step
Could anyone please help me? Thanks!
DanPatterson
MVP Esteemed Contributor
Import 3D Objects (Data Management)—ArcGIS Pro | Documentation
If the coordinate system isn't defined, it needs to be before you can use the Project tool (eg Define Projection to tell it what it is first
... sort of retired...
