Imagery Layer Not Loading to Map
9167
8
10-18-2021 11:29 AM
TylerTownes
Hello,
ArcGIS Pro is showing I have both Imagery and Imagery Hybrid basemaps.
However, when I click to load, nothing loads into my map.
Similarly with the the Imagery Hybrid, except the hybrid reference layer loads, but not the imagery.
Any ideas?
Thank you,
Tyler
ArcGIS Pro 2.8.0
JayantaPoddar
Have you tried the following options.
1. Reboot your machine. Open a new ArcGIS Pro instance. Try adding the imagery basemap again.
2. Reset ArcGIS Pro Application Profile. Resetting your ArcGIS Desktop (ArcMap) application... - Esri Community
3. Download a fresh installation setup of ArcGIS Pro (from My Esri) > Repair/Upgrade ArcGIS Pro using the setup.
Think Location
TylerTownes
@JayantaPoddar, now that you've mentioned it I've completed your suggestions 1 and 2 with no luck.  IT will be helping me with #3 soon.  Have you (or anybody) heard of this issue before?
Thank you,
Tyler
ArcGIS Pro 2.8.3
TylerTownes
@JayantaPoddar; Ok, tried all three suggestions...no dice.  Additionally, I tested all basemaps and found four are not working:
Imagery,
Imagery Hybrid,
Oceans,
USA Topo Maps
If the basemap has a text reference layer, the reference layer will display, but the imagery will not, as seen in the following image:
Here is a shot of the Streets basemap which is working correctly (same project file).
Any further suggestions would be much appreciated.
Thank you,
Tyler
ArcGIS Pro 2.8.3
JayantaPoddar
Hope you have already raised a case with Esri Support.
Under C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\mapping , I see a file _basemap_definitions.py
I have zipped and attached the file from my folder. Please verify if the file in your system is exactly same (Open in IDLE). If not, you may try replacing the file.
Think Location
JacobLyons
Did you ever get this resolved? I'm running into this exact issue on ArcGIS Pro 3.3.1.
LarissaY
I am also having the same problem.
JeffGardner_Safelite
I'm also running into this issue. I'm on Pro 3.4.2.
TravesCollie
So I had this issue as well the solution i found was if you go to portals you will see two portals the one that says www. arcgis.com may or may not be signed out. If it is signed out just sign back in with you arcgis profile and then reload the basemap and it should work otherwise you have another problem
