I am using ArcMap 10.6.1. Here is the problem I am having: I have georastered a .jpeg of a campus map I am making. Once I georastered, the map image became slanted. I have tried to rotate it, etc. It still looks slanted. It prints this way, too. How can I
1865
04-09-2019 02:50 PM
TaylorBoles
this is what is happening
curtvprice
Imagery and Remote Sensing‌ is the forum for you. I think you meant georeferenced?  I suggest removing your georeferencing and starting again from scratch, being careful with setting up your control points (remember, image > map) and not updating georeferencing until you know your links are good, based on the statistics shown for the links.
Before you start again, it probably would be good to re-read the help:
http://desktop.arcgis.com/en/arcmap/latest/manage-data/raster-and-images/fundamentals-for-georeferen...
curtvprice
I found this youtube video that walks you through the process, though he probably uses more control points than needed
https://www.youtube.com/watch?v=s-DERzmbIgM
