Hub and Spoke? Please help
3029
11-17-2020 07:22 AM
FenHow
Hello, looking for a place to start to accomplish this objective.
I want to have one point when I select this point it blows out into 20 points around it, each point around it holds a different set of information. Each point is connected to the main point by a line.
What is this called? Can someone please point me in the right direction?
I have seen something like this before on an ArcGIS map but cannot seem to find a tool or tutorial.
Many thanks.
Fen
RickeyFight
@FenHow
What you are looking for is clustering. I am not sure if what you are looking for is exactly available.
https://pro.arcgis.com/en/pro-app/tool-reference/spatial-statistics/an-overview-of-the-mapping-clust...
FenHow
Thank you, that looks close. I will look deeper into that and see if it fits.
I have seen this before in O&G applications. Where you would have one surface well location that had several bottom hole locations when you clicked on the surface location all the bottom holes would show up.
When the bottom holes showed up as points, each point had its own attributes but were related / tied to the surface hole location.
Thank you so much for helping me.
Fen
RickeyFight
@FenHow
You could also be looking for Related tables.
https://pro.arcgis.com/en/pro-app/help/data/tables/view-related-data.htm
