How to share an Elevation layer from a local scene with the set coordinate system of the scene instead of its own coordinate system
1111
07-06-2023 01:03 AM
Labels (2)
Stefan_Thorn
When I have a local scene in Pro and I publish a 2D or 3D layer to AGOL or Enterprise, the coordinate system , i.e. wgs84 mercator, that is set for that scene will be used to give the published feature layer that same coordinate system even it the layer has i.e. RD_New.
But when I publish my own created ground layer the published feature layer will keep the coordinate system from the layer instead of the wgs84 mercator. So I have to create a new raster with that coordinate system, add is ground layer and then publish it to AGOL or Enterprise.
Thanks!
