How to select features based on a value from Inspection Table
1431
09-21-2023 01:47 PM
AndrewMulford
I have created an inspection table associated with a feature layer using the established workflow. Using Field Maps I have generated inspections for each feature. Now I want to be able to select all features with a certain inspection value. Is there any way to do this?
AndrewMulford
ZachBodenner
MVP Regular Contributor
In Field Maps? Probably not, but if you can do the workflow in Pro, then you could join up the parent layer to the inspection table (based on whatever field your relate uses), and then do a select by attribute?
Happy mapping,
- Zach
