How to Replicate ArcGIS Pro's Visibility Scale by Symbology?
812
06-17-2020 07:27 AM
RVx_GaslineGiS
In Pro, you can have a layer with graduated symbology that has a different visibility range for each symbol. So, for example, with a gas  distribution main I can have high pressure mains show up at a higher visibility range than low pressure main.
When I publish a Pro map as a feature layer/map image layer into Portal, it does not include that functionality. Is there a way to maintain that functionality when publishing or to otherwise replicate it? I understand I could just create 4-5 layers and set the scales on those...but I feel like there should be a more elegant solution if its a function that exists in Pro?
