How to "link" two map frames with map series using Arcpy?
1158
01-20-2022 06:34 PM
Newuser27
I am trying to create a two panel map layout where the first map frame has a map series enabled and the second map frame copies the extent of the first map frame but it is one page ahead.
I can currently do this is ArcMap using arcpy, but I cannot seem to get the functionality to work in Pro.
I have tried this, but the second map frame will not iterate as the first map frame changes pages:
aprx = arcpy.mp.ArcGISProject("current")
one = aprx.listLayouts()[0]
df1 = one.listElements("MAPFRAME_ELEMENT","Map Frame")[0]
df2 = one.listElements("MAPFRAME_ELEMENT","Map Frame 1")[0]
ms = one.mapSeries
for pageNum in range(1, ms.pageCount):
    #set map series to have the extent of the PageNum + 1 (one page ahead)
    ms.currentPageNumber= pageNum + 1
    #get extent of Frame 1 and set Frame 2 to have the same extent as the first frame
    extent = df1.camera.getExtent()
    df2.camera.setExtent(extent)
    #reset the extent of the first Frame back to the correct page
Does anybody have any ideas?  Thanks.
KariBuckvold
Did you ever figure this out?  This hack was really helpful in desktop but I need to get this going for Pro.
