How to enable two Map tools at same time using ArcGIS PRO SDK Using C#
998
05-20-2021 02:28 PM
sudhansuMishra
We are working on a project using ArcGIS Pro SDK. The following is the problem statement.
User wishes to enable two map tools at same time, for example if user clicks on first tool, then another tool should be enabled as shown in the attached screenshot.
This is already implemented in ArcMap and it is working.
Your inputs/ideas are most appreciated.
Pic.1 ArcGISPro
User selected "Modify Annotation Tool”, now user wants to enable "Point Rotate Tool" automatically
 Pic.2 ArcMap
Working functionality in ArcMap.
Tags (1)
