How to create and edit microsoft word template(document) in Arcgis Pro Layaout ?
2017
10-31-2017 02:03 AM
tanerkoka
Is it posible to create , edit and importing and word template (documents) in Arcgis Pro  Layaout ? Because we want to create word Plan note (expresses the written from that facilitates the explanation of the plan) .
Tags (1)
TedKowal
Honored Contributor
I do not believe that is an option.  If MS Access (Personal Databases) were recognized then you would have a chance in doing it from there wrapped up in a MS Access Script and possible runing the script through ARC GIS Pro.  But there are no current plans on implementing MS Access to GIS Pro.  However you can vote this as an idea and possible they may consider it..... https://community.esri.com/ideas/12662
tanerkoka
Thanks Ted , Do you know if Microsoft Word was added in Arcgis Pro sdk or not?
Best Regards
TedKowal
Honored Contributor
No I don't think so directly, however I see no reason why you could not include the Word API reference into a .net program.  So if you want to do the heavy lifting, you could pass Word the necessary stuff you want.
Say you wanted to open a word template .... and pass it the necessary data...
eg... wdApp = new Microsoft.Office.Interop.Word.Application();
