How to add excel spreadsheet into a shapefile in arcgis pro?
13302
12-24-2019 04:42 AM
KeWang1
How to add excel spreadsheet into a shapefile in arcgis pro? I tried the "Add" function, but the result is "Null". For example, I have the population for each country excel spreedsheet, I also have world country shapefile, how to add the population to the country shapefile so I can show in the map?
XanderBakker
Esri Esteemed Contributor
Hi Ke Wang ,
I'm going to share a couple of links that should help you understand the steps:
After these step you will have enriched your country featureclass with the population from the Excel file.
XanderBakker
Hi Ke Wang ,
KeWang1
Thanks a lot!!!!!!!!!!!
