New to this and have trial of ARCGISPRO. I have a table and I added a new field. I now want to copy about 2000 data points from excel and paste in that field. I can get it to paste ONE, but not the entire column. Any help? Thank you. ARCGIS newbie 😉 excel field table editing import fields
If they have a common id field, then you should be doing a 'join' to simplify the operation.
I'm sorry but could you elaborate. I do know how to JOIN, but if I have an excel file with the field (common field to the table in GIS) then what is the operation? THANKS!
Another option, if you want to add the columns permanently
Join Field—Data Management toolbox | ArcGIS Desktop
As Dan mentioned, do the excel-to-table first, and I would use the add-join (or Add Relate ) to test the results (both which can be temporary, or at least do not permanently/physically add the fields), but then if you want it permanently added to you table, use the Join Field to add the columns to the in_data....you can also filter for just the columns you want. The in_field and join_field do not have to be the same name, but do need to have equal values (which is why testing first is helpful.
JoinField_management (in_data, in_field, join_table, join_field, {fields})If the columns do not add correctly or you get too many fields added, you can always use Delete Field—Data Management toolbox | ArcGIS Desktop
Keep in mind that if you add fields, and there is already a field with that name, the new fields will get a _1 added to the new fieldname (at least in Desktop...assuming same in Pro)
Just some options...but I would go with Dan's suggestion first.
thank you both - i will give this a try.
