How do you symbolize polygons using unique values while maintaining appearance of different outlines
1491
03-02-2020 12:34 PM
DaveStewart1
Good day,
This may be difficult to explain which is why I have attached photos.
I'd like to visualize a polygonal layer using unique values (different colours for each type of "Class") while also maintaining the outline of each polygon. Even with a transparency on the layer the polygons "on top" are hiding the outline of the polygons "underneath". I'd like the layer to have a fill  as well (which is part of the problem). Please see the attached - the visualization will make more sense of the situation.
Basically its treating the polygons like sheets of paper covering each other up - but the translucency does not account for the outline.
This may or may not matter but I'm using the latest version of Pro.
Any ideas on how I can make this work?
Thank you.
DaveStewart1
I have rethought this and settled on the outlines themselves (no fill).
Although this issue may be a problem for others.
